Enables secure socket layer (SSL) access to the switch on the default port (443).
Disabled.
If an SSL certificate and key are not present in switch, this command will result in automatically generating both.
Use this command to allow users to connect using a more secure HTTPS connection.
To use secure HTTP access (HTTPS) for web-based login connections, you must specify HTTPS as the protocol when configuring the redirect URL. For more information about configuring the redirect URL, see the configure netlogin redirect-page command.
The following command enables SSL on the default port:
enable web https
This command was first available in the ExtremeXOS 11.2.
